I have a problem with the Fios HDTV box not communicating via the HDMI cable to my Olevia HDTV 237T. Every time I start up or change channels from HD signal to SD signal, the TV goes to blue screen with no signal. The only solution found so far is to unplug the HDMI cable from the TV and plug it in again. I tried an HDMI switcher box in-between but with no real difference in the result. Is there a solution to be found before I wear out the connectors on the cable?
The only other thing you could do would be to try upgrading the firmware on your television. That might fix the HDMI sync issues. If it doesnt, the only other option would be to use a component cable. It will give you the same 1080i quality picture that our set top box puts out. That HDMI sync problem is the biggest problem that any device that communicate HDMI can encounter. I'm sorry for the trouble you are experiencing.
