Customers With Disabilities
  • RESIDENTIAL
  • BUSINESS
    Verizon Business Sites
  • WIRELESS
KS_NYC
0 Kudos
Accepted Solution
Help - On Demand content looses signal every 20-30 seconds for a couple of seconds
I just got my new Verizon Fios setup over the weekend.
Live TV and Internet is working great – all as expected.
Although, I have been consistently having one issue – any On Demand content that I play looses signal i.e. Audio breaks and Video also looses signal for a couple of seconds or so every 20-30 seconds.
At first I thought this will go away, but the experience is consistent and frustrating with on demand. (issue is only with on demand, live TV and internet work just fine)
After reading some of the updates – I made sure all cables are tightly connected. (that is the only trouble shooting I have done)
Wanted to see if there is any suggestion or do I have to call the technical team to fix the issue.
Employee
Anthony_VZ
0 Kudos
Re: Help - On Demand content looses signal every 20-30 seconds for a couple of seconds
I am sorry to hear about the problems you are having with your On Demand service. The On Demand goes through the internet which passes through the router. One thing you can do to fix this is to reboot the router. Simply turn it off and back on. If this doesn't correct it, you can also try resetting the router by holding in the reset button in the back of the router for 15 seconds. Please let me know if that doesn't work so we can assist further.
Anthony_VZ
**If someones post has helped you, please acknowledge their assistance by clicking the red thumbs up button to give them Kudos. If you are the original poster and any response gave you your answer, please mark the post that had the answer as the solution**
Notice: Content posted by Verizon employees is meant to be informational and does not supersede or change the Verizon Forums User Guidelines or Terms or Service, or your Customer Agreement Terms and Conditions or plan
KS_NYC
0 Kudos
I removed the power on the router for 2-3 mins and powered back. It seems to be working fine now. Thanks a lot.
Verizon
  • Services
  • Shop
  • Support
  • Site Feedback
  • Announcements
Shop FiOS
  • FiOS Internet
  • FiOS TV
  • FiOS Digital Voice
  • FiOS Bundles
  • Flex View
Account & Services
Email, News, & TV
  • Check Email
  • TV Listings
