I need a replacement power cord for my Set Top Box (Motorola QIP7100-2). I am mounting a television on a wall and the electrical power outlet for this location is a very tight fit (approximately an inch clearance). Does anyone know where I may obtain a replacement power cord which has a low profile (right angle or other plug shape that won't extend out from the wall more than an inch)?
Correct answers
Much Thanks, the piglet solution will work!
Something like this? (I am not the seller!!) You could ask them a question about the exact clearance dimensions....
Thanks for the reply. Your example is close (it looks like a power cord for a laptop). On the STB plugin, the shape is slightly different, one side square / one side rounded. I will check eBay to see if they have any like to it. I think the cable is a NEMA 1-15P to IEC 60320-C7 polarized cable (assumed this from viewing cable manufacturer's sites; I couldn't find any specifications for the cable in the STB manual and a with a call to Verizon, the only advise I got was check the manual or try Radioshack (Radioshack doesn't carry it).
I don't know if they make these, but a "low-profile pigtail" would allow you to use the provided power cord. I use these around the house but they are not low-profile and are generally 3-prong. The allow you to avoid plugging the power bricks into something, thereby losing outlets on powerstrips and wall receptacles. Good luck!
I've had success using a short adapter cable like this ....
http://www.amazon.com/Cord-degree-rotating-wall-adapter/dp/B003I7FEHQ
I managed to find mine at a local home improvement store rather than online, but it's essentially the same thing as shown here ... a short pigtail.
