Customers With Disabilities
  • Shop
    Order Services
    See All Plans & Bundles
    Special Deals
    Moving
    Current Customers
    Add or Change Services
    Renew or Change Bundle
    Find out which Verizon services are available at your address.
  • My Verizon
    Email & Calls
    Check Email
    Verizon Visual 411
    Bill & Payment
    View Bill
    Pay Final Bill
    Manage Auto Pay
    Manage Paper Free Billing
    My Services
    Suspend My Service
    Review Account
    Manage My Internet
    Manage My Voice
    My Rewards+
    Manage My Rewards+
    Refer a Friend
  • Support
    Community help
    Search Support
    Connect with us
    Verizon on Facebook Verizon on Twitter Verizon on Google Plus Verizon on YouTube
  • Watch Fios
    Watch thousands of your favorite TV shows and movies On Demand and Live. Rent or buy your favorites
    and watch them on any device. Or, check what's on tonight and program your DVR. You can do it all!
    Watch Free TV & Movies
    Rent or Buy
    Set your TV Viewing Experience
  • Trending
    Check out this personalized, real-time feed featuring the latest content and entertainment from around the Web including new headlines, sports, entertainment and more.
    News & Lifestyle
    Have a laugh, learn a trick and discover the awesomeness of Fios. Explore Fios Lounge today.
    Fios Lounge
    Main
    Play
    Know
    Live
0 Kudos
FIOS TV sound problem
I've had a problem with drop off sound for some time. I usually channel up one on my remote and then channel back to the channel I was watching to get the sound back. I've reset my box, called Verizon and had my box reset remotely, and recently had new sofware added to  my Motorola box remotely via chat support. I still have the problem. Last Saturday, I used on demand for the 1st time to watch a movie and every 10 minutes, the sound would go off and come back after 2 minutes. Can anyone help? I have a Sony Bravio LCD TV with HDMI cables hooked to a Verizon HD Motorola box. Thank you
Gold Contributor I
Plan: Prime HD 50/25
Re: FIOS TV sound problem
Common problem with HDMI cables and some model TV's having trouble with decoding and syncing various digital audio formats.  Try the change to the STB described here ...
http://forums.verizon.com/t5/FiOS-TV-Technical-Assistance/Vizio-with-no-HD-audio/m-p/272841/highligh...
0 Kudos
Hello and thank you for responding. I tried your suggestion of pressing power and then menu on my box. I got the main menu and scrolled down to "audio." I then arrowed over to the drop down menu: Set top box volume, audio format, volume control and dynamic range. I did not see a "white users screen" or "additional HDMI settings."  I did notice that my settings for "set top box volume is 24, my audio format did read "surround sound" which I do not have so I changed it to "stereo." The volume control reads "variable." My other choice is "fixed." and finally my dynamic range reads "heavy." Would you have any other suggestions to help me fix my drop off problem? Thanks
Gold Contributor I
You're not in the right spot ....
With everything turned ON and you watching a regular TV channel, you must press "power", "select", then "menu" (each individually and about 1/2 second apart directly on the STB) to bring up the STB configuration menu.  This will be a screen with a white background and black text -- the top line of which will read "User Settings".
What model STB do you have?
0 Kudos
Hello lasagna. Thanks again for responding. It took me several tries, but I managed to get the white screen/black text and changed the settings. My STB is a Motorola HD QIP6200-2. At first, the screen showed that the "Audio Output" was N/A and I could not access it.  I right arrowed anyway and the Audio Output became accessible(can't figure out how that happened). I continued to right arrow until L-PCM appeared in the box and then powered off and then on again. It seemed like the volume increased after saving the settings. I've had this audio drop off problem for a long time and I appreciate your assistance very much. Hopefully, this will fix it. Thank you!
Copper Contributor
0 Kudos
I have the same sound problem when the show is encoded in 2-channel dolby digital.  As long as it is in 3/2 dolby digital, the audio is fine.  Except on some commercials.  I went into that menu you referenced and changed the setting from 'Auto' to 'L-PCM' but that had no effect on 2-channel dobly digital shows.  I just recently swapped back to HDMI from component to cinduct this test because the same thing was happening when using the component video cable.  Except when using the component cable, the 'Additional HDMI settings' menu is not available.
I should mention that I use a Sony STR-DE845 receiver that does not support HDMI.  So I can only use the TosLink digital audio cable.  This is connected directtly from the DVR to the receiver and the HDMI goes from the DVR to the TV.  I'm on my third FIOS DVR.  My first one was the older 6416 model and there were never any problems until it died.  It was replaced with the 7216 and that's when the problems began.  That was replaced with the 7232 because the FIOS tech could not figured out what was happening.  Then two days later the problem started again.
Now there is no sound on 2-channel digital and some 3/2 digital commercials.  I know when I call Verizon again for about the 7th or 8th time about this very problem, they'll have me reboot the thing.  Then they'll remotely reset it.  But none of that will work because that is what they did every previous time.
0 Kudos
For the past two or more years I've had drop-off sound problems with FiOV TV that Verizon doesn;t appear to know how to fix.  They have reset my DVD box remotely a number of times anf told me that it was fixed or it was not their problem. Service reps have walked me through the menue, had me reset things twice and told me that the problem was fixed but  nothing has worked.  I have Diredct TV in the house and when I by-pass Verizon there is no problem with the TV Anyone else have this problem?
0 Kudos
jamesd3rd, I'm having the same issue.  Have you found a fix?
I've got my Cisco CHS 435HDC.  It's connected to my Denon 3313CI via HDMI.  Audio seems to work fine with 3/2 dolby digital however if a show, or commercial is using 2 channel dolby digital the sound stops.  Audio immediatley begins working again when it switches back to 3/2.  I'm running the latest firmware on my AVR and other sources utilizing 2 channel audio over hdmi (PS3 and Computer) seem to work fine.
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Renew Your Contract
  • Manage Services
  • Announcements
Support Tools
Watch Fios
Trending
  • Visual 411
