Customers With Disabilities
  • Shop
    Order Services
    See All Plans & Bundles
    Special Deals
    Moving
    Current Customers
    Add or Change Services
    Renew or Change Bundle
    Find out which Verizon services are available at your address.
  • My Verizon
    Email & Calls
    Check Email
    Verizon Visual 411
    Bill & Payment
    View Bill
    Pay Final Bill
    Manage Auto Pay
    Manage Paper Free Billing
    My Services
    Suspend My Service
    Review Account
    Manage My Internet
    Manage My Voice
    My Rewards+
    Manage My Rewards+
    Refer a Friend
  • Support
    Community help
    Search Support
    Connect with us
    Verizon on Facebook Verizon on Twitter Verizon on Google Plus Verizon on YouTube
  • Watch Fios
    Watch thousands of your favorite TV shows and movies On Demand and Live. Rent or buy your favorites
    and watch them on any device. Or, check what's on tonight and program your DVR. You can do it all!
    Watch Free TV & Movies
    Rent or Buy
    Set your TV Viewing Experience
  • Trending
    Check out this personalized, real-time feed featuring the latest content and entertainment from around the Web including new headlines, sports, entertainment and more.
    News & Lifestyle
    Have a laugh, learn a trick and discover the awesomeness of Fios. Explore Fios Lounge today.
    Fios Lounge
    Main
    Play
    Know
    Live
0 Kudos
Accepted Solution
HBO "not-subscribed" using HDhomerun cable card tuner
I've called support a few times about this and they confirmed that I'm subscribed to HBO but the follwing shows in the log:
19700101-00:00:00 System: reset reason = power on
19700101-00:00:01 CableCARD: M-CARD inserted
19700101-00:00:03 System: network link 1000f
19700101-00:00:04 CableCARD: Motorola card (0000:0625)
19700101-00:00:04 CableCARD: authentication status: authentication in progress
19700101-00:00:04 CableCARD: authentication status: authentication success, activation needed
19700101-00:00:09 System: ip address obtained: 192.168.1.9 / 255.255.255.0
20121107-20:58:28 CableCARD: time changed from Thu Jan 01 00:00:15 1970 to Wed Nov 07 20:58:28 2012
20121107-20:58:31 CableCARD: Tuner0: vchannel 899 (165MHz-670) access = not-subscribed
I can tune all other channels I'm subscribed to in Windows media center, and I have run the digital cable advisor/installed playready. I've called support a few times but it doesn't seem the phone techs are familiar or trained in activating cable cards, and if the logs above is correct I'm still not properly activated.
Thanks for any help!
Platinum Contributor I
Re: HBO "not-subscribed" using HDhomerun cable card tuner
you should have gotten a letter about reactivating your cable card andit lets you do it online.  if you didn't then try a live chat and ask them to validate your cable card, make sure you have your host id, cable card id, and data id ready. they will need that.
or call them if you can't get through on live chat. 800 VERIZON
0 Kudos
I called a few times and they said the card was activated, but I will try live chat and see if they can validate. Thank you for the suggestion.
0 Kudos
If they validate and don't ask you for your host id and stuff, then you can pretty much rest assured that they didn't do it right..
Not sure how to make sure they do it right, but its needed.  maybe have them deactivate the box and reactivate it with all of your info.
0 Kudos
After spending an hour or so via the support chat option they decided to send me another cable card, and unfortunately the same problem persists. The HD Homerun software says Activation "none" even though I have been assured by Verizon that it has been activated.
I researched the issue on the manufacturers forums and found this post to be very similar to mine, and the solution being that since it is not a TIVO that it cannot be automatically activated and must be done "manually". Can someone from Verizon who knows what they are doing please contact me and get this fixed? Very fed up at this point.
Ref:
http://www.silicondust.com/forum/viewtopic.php?t=13655&highlight=activation
0 Kudos
[ Edited ]
you gave them your host id and data and cable card ID ?
did they write it down?  If they were trying to do it without it, then you'll be stuck.   I didn't notice you say anything about your host id etc.
in fact next time you talk to them, ask them if they have it and if they can read it back to you.
if they don't have it, or can't see it, then that is why you can't watch HBO.   They need your host id programmed in their systems.
0 Kudos
I'm having the exact same issue here.  I have HD HomeRun with a M CableCard connected.  All stations work except the channels for HBO and Cinemax.  I spent over an hour on the line with Verizon tech support with 2 different advisors and no luck getting it resolved.  In fact, we looked at this thread here and tried the manual system and still no go for HBO and Cinemax.
Anybody have luck with this?  Please help.
0 Kudos
if you go to channel 131 does it show you your current info like your data ID and cable ID and host ID?
0 Kudos
I am having the same problem. I go to channel 131 and see the information channel. I did noticed that the status of the Cablecard is one way. I thought I read that it has to be two way for HBO to work?
[ Edited ]
Problem resolved.  My issue was that it would say Subscription Required and then switch over to Activiation Required for all the HBO and Cinemax channels.
The message then gave me a statment that "Not digital cable ready".  So I have to make my Windows Media Center digital cable ready.  Did that by going to WMC menu, <Extras>, <Extras Galler>, <Digital Cable Advisor>.  Once I went through Didital Cable Advisor, I was able to get the HBO and Cinemax channels.
Here's a link that I found that addresses this:
 http://connecteddigitalworld.com/2009/11/09/installing-a-cablecard-digital-cable-tuner-with-the-new-...
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Renew Your Contract
  • Manage Services
  • Announcements
Support Tools
Watch Fios
Trending
  • Visual 411
