Customers With Disabilities
  • Shop
    Order Services
    See All Plans & Bundles
    Special Deals
    Moving
    Current Customers
    Add or Change Services
    Renew or Change Bundle
    Find out which Verizon services are available at your address.
  • My Verizon
    Email & Calls
    Check Email
    Verizon Visual 411
    Bill & Payment
    View Bill
    Pay Final Bill
    Manage Auto Pay
    Manage Paper Free Billing
    My Services
    Suspend My Service
    Review Account
    Manage My Internet
    Manage My Voice
    My Rewards+
    Manage My Rewards+
    Refer a Friend
  • Support
    Community help
    Search Support
    Connect with us
    Verizon on Facebook Verizon on Twitter Verizon on Google Plus Verizon on YouTube
  • Watch Fios
    Watch thousands of your favorite TV shows and movies On Demand and Live. Rent or buy your favorites
    and watch them on any device. Or, check what's on tonight and program your DVR. You can do it all!
    Watch Free TV & Movies
    Rent or Buy
    Set your TV Viewing Experience
  • Trending
    Check out this personalized, real-time feed featuring the latest content and entertainment from around the Web including new headlines, sports, entertainment and more.
    News & Lifestyle
    Have a laugh, learn a trick and discover the awesomeness of Fios. Explore Fios Lounge today.
    Fios Lounge
    Main
    Play
    Know
    Live
0 Kudos
P265 Remote won't control volume on Pioneer TV AFTER I press the final OK to lock in programming
I have a variation on the common problem with getting the P265 to control the volume on my pioneer TV.
I go through the setup instructions:
- Press OK and 0 for 5 seconds
- enter 290
- Press channel up until it turns off my TV
- Test Volume +-, mute, input, EVERYTHING WORKS FINE
- Press OK to set the programming - red light blinks and goes out just like it is supposed to
BUT, once I push that final OK, the remote no longer controls the Volume.  IT still works for on/off, mute, input, but NOT for volume.  Somehowe volume was working before I pushed the final OK to finish the programming, but once I push OK the remote forgets how to control the volume (but still works of on/off, mute, etc).
Any ideas?
thanks,
m
Bronze Contributor III
0 Kudos
Re: P265 Remote won't control volume on Pioneer TV AFTER I press the final OK to lock in programming
Go here:
https://www22.verizon.com/ForYourHome/VZRepair/vziha/Service.aspx?ihaweb=WebRemoteSetup
  1. Choose your remote.
  2. Select "I want to setup my Verizon remote with my TV".
  3. Click Next.
  4. Find and Highlight your TV manufacturer.
  5. Click Next.
  6. (This page is the setup process you've just completed.) Click No.
  7. Follow the instructions on this page.
If this still does not do it, then you can try the Key Fix.
Key Fix
If your remote control is programmed for your TV, but the <VOL>, <Mute>, or the <A/V> keys do not work correctly, then you can try using the Key Fix feature to fix the buttons.
1. Press and hold the OK and * buttons simultaneously. • The Red LED will blink twice and then stay on.
2. Press and hold the key that does not work correctly. The remote control will try a new code every second.
3. Once the TV responds correctly, release the button.
4. Press OK to save the current settings and finish programming your remote control.
Hope this helps.
Find this post helpful, informative or just something you agree with? Click the red ‘thumbs-up’ button.
Did this post solve your problem? Click the green ‘Accept as Solution’ button.
0 Kudos
I'm having the same issue with a Samsung. The key fix doesn't work as it actually programs fine UNTIL "OK" is hit to save settings. VERY frustrated at this point.
0 Kudos
Did you ever get it to work? Are you setting volu,e controls to "Fixed' or "variable' I've tried both same thing happens except the box controling the volume from the STB is "fixed" at max, the bar will decend down but the volume doesn't change until you hit zero then the sound goes off.
0 Kudos
Hi lilunder2002,
I'm afraid I can't help you make the remote work as I don't have any more suggestions than the ones I listed above. MarkR has yet to log in since I posted my suggestions, so I don't know if he had more success.
As for the Fixed/Variable setting: FIXED prevents the STB pre-amp from being changed. VARIABLE allows the STB pre-amp levels to be changed. However, the STB volume only controls the analog audio outputs (coaxial cable or red/white audio outs). The digital outputs (digital audio coax, digital audio optical, HDMI) can be either on or off, but cannot be volume controlled by the STB.
So as far as I can tell, your options are:
  1. Revert back to analog connections (coax, composite, component).
  2. Continue using 2 remotes.
  3. Purchase the 4-device remote from Verizon and hope it has the right code for your TV.
  4. Purchase a universal remote that can be programmed for both Verizon FiOS and your TV.
Wish I had better news. Hope someone else can weigh in and offer more help. Best of luck.
0 Kudos
Oh thank you for you're help, I guess I didn't state that I'm not using an HD TV so I'm infact using the RF (red,white,yellow) connections. I thought that was possibly the isuue and was going to try the coax next, however from your info it seems that since these are both analog connections that probably won't fix it either Smiley Sad If I get it to work I'll definitely update!
P.S - I was also wondering if it has anything to do with the TV set acting on AV1,AV2 etc....maybe I should rifle through the TV settings to check for a "cable" option..
0 Kudos
I had assumed that you were using a digital connection because of your description. But if you are in fact using analog connections, then the volume control on the STB should work.
To set the STB to control the volume, do the following:
Menu > Settings > Audio > Volume Control > Variable > OK > Exit
  1. On the remote control press & hold the OK & 2 buttons, release together. (The LED will blink twice, then stay lit.)
  2. Press 9 - 5 - 5. (The LED will blink twice, then stay lit.)
  3. Press the STB button. (The LED will blink 3 times, then stay off.)
The volume and mute will now be controlled through the STB. Set the TV volume to a moderate level. Then use the remote control normally to control the volume through the STB.
0 Kudos
Sorry, I've been out of town for a while.
I tried lacticacidtrip's suggestions, but ran into an immediate problem - when I push TV and Fios TVbuttons together, the remote does NOT flash twice.  I tried it with both the TV button and the STB button since the instructions said use the TV button but it looked like the right button was highlighted and that is STB on my control. Nothing.
Similarly, when I tried thekey program approach pushing OK and * button - nothing, no blinking or staying on.
So, I've asked verizon to send me another remote.  I'll ley you know if that works Smiley Sad
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Renew Your Contract
  • Manage Services
  • Announcements
Support Tools
Watch Fios
Trending
  • Visual 411
