Customers With Disabilities
  • Shop
    Order Services
    See All Plans & Bundles
    Special Deals
    Moving
    Current Customers
    Add or Change Services
    Renew or Change Bundle
    Find out which Verizon services are available at your address.
  • My Verizon
    Email & Calls
    Check Email
    Verizon Visual 411
    Bill & Payment
    View Bill
    Pay Final Bill
    Manage Auto Pay
    Manage Paper Free Billing
    My Services
    Suspend My Service
    Review Account
    Manage My Internet
    Manage My Voice
    My Rewards+
    Manage My Rewards+
    Refer a Friend
  • Support
    Community help
    Search Support
    Connect with us
    Verizon on Facebook Verizon on Twitter Verizon on Google Plus Verizon on YouTube
  • Watch Fios
    Watch thousands of your favorite TV shows and movies On Demand and Live. Rent or buy your favorites
    and watch them on any device. Or, check what's on tonight and program your DVR. You can do it all!
    Watch Free TV & Movies
    Rent or Buy
    Set your TV Viewing Experience
  • Trending
    Check out this personalized, real-time feed featuring the latest content and entertainment from around the Web including new headlines, sports, entertainment and more.
    News & Lifestyle
    Have a laugh, learn a trick and discover the awesomeness of Fios. Explore Fios Lounge today.
    Fios Lounge
    Main
    Play
    Know
    Live
0 Kudos
Accepted Solution
remote control volume control issue
I recently went through a series of equipment switches.
My initial set-up was a 4-year-old Samsung Slimfit 30" tube tv with the FIOS SD STB (Motorola QIP 2500-3). We recently upgraded to a Samsung 40" LCD TV (Model #LN40530F). About a week after getting the new TV, we finally decided to upgrade to HD service from Verizon, and we now have a new HD STB (Motorola HD QIP 7100 1). Everything is working fine except for a little idiosyncracy that I'm hoping to tweak.
Up until the new HD STB, I was able to simply hold down the volume button on the remote control to adjust the volume level, whereas with the new STB and the new remote (the kind that only has a TV and STB power button at the top, instead of 4 different modes), I have to repeatedly press the volume button to adjust the volume level.
Is there a way to re-program the remote so that I can simply hold down the volume button (as opposed to repeatedly hitting he volume button) to adjust the volume levels? Yeah, I'm lazy :-)
Platinum Contributor I
Re: remote control volume control issue
Tv+ok for two seconds and let them go. Device keys at top will blink. 0729. Your done. Smiley Happy try it. The newer samsungs seem to like that one
Awesome. Fixed it just right. Thanks!
I tried everything in remote manual with no success. So happy I found this thread--worked instantly. Thanks!!!
0 Kudos
The tv code 0729 solves the problem with the Samsung tv voluyme control for the Phillips FIOS remotes, but I can't find the code, if there is one, that works for the Verizon P265 remote.  Anyone know the answer?
Had the same problem as you above. Searched the internet and found the instructions below that worked for me. Good luck and let me know if it worked for you.
"Reprogram the remote. If you have the remote with the AUX and DVD buttons use the 4th code for Samsung TV. On the new remote (P265) use the Samsung code and it is the 4th code also. Press and hold the <OK> and the 0 keys together, and then enter 331. Then press the <CH +> button 4 times, BUT block the the end (IR light) of the remote for the 1st 3 presses. On the 4th press of the  <CH +> button the tv will turn on (or off), wait a few seconds, then press <OKto confirm."
0 Kudos
This doesn't appear to work with the VZ P265v1.1 remote control.   Do I need to do something different?
Thanks.
0 Kudos
I was having the same issue with my new Samsung.  0729 worked perfectly.  Thank you!!
0 Kudos
Thanks! Have been living with this problem with the P265 for several months, finally decided to look for a solution, and you provided it. I really appreciate it! And my wife will love you for it. Smiley Very Happy
Justin
QIP7232, QIP7100-P2, IMG 1.9.1
Keller, TX 76248
0 Kudos
This issue w/our Samsung 32" bedroom TV was driving me crazy. The suggested solution for the P265 worked on the first attempt. Thanks you !!
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Renew Your Contract
  • Manage Services
  • Announcements
Support Tools
Watch Fios
Trending
  • Visual 411
