Customers With Disabilities
  • RESIDENTIAL
  • BUSINESS
    Verizon Business Sites
  • WIRELESS
fjscott
0 Kudos
Wasps nest in Verizon FIOS equipment
I have Verizon equipment exposed to the outdoors. Noticed a wasp entering the box through a hole in  the bottom.  Is it okay to use a wasp spray  - will need to spray into the equipment area?  Not sure if this would interfere with any wiring or other parts. Thanks.
tricia
Re: Wasps nest in Verizon FIOS equipment
Call VZ 1800-8374966 repair tech will go out to remove, And yes you can spray Wasps spray if there are not to many
Gold Contributor VII
Smith6612
[ Edited ]
I would avoid spraying anything that might be conductive into the ONT. Have a technician come out if you are unsure of the spray potentially causing harm to the ONT. If it's at the top of the ONT and there's no metal/lights/jacks, it should be just fine to open up and spray. If it's near any of the connectors, have a tech remove it so they don't try to blame you for breaking an ONT in case the worst does happen. If you're creative, you could probably find a way to make the Wasps leave the ONT or kill them slowly to avoid using the spray :smileyhappy:
Verizon
  • Services
  • Shop
  • Support
  • Site Feedback
  • Announcements
Shop FiOS
  • FiOS Internet
  • FiOS TV
  • FiOS Digital Voice
  • FiOS Bundles
  • Flex View
Account & Services
Email, News, & TV
  • Check Email
  • TV Listings
