caller id no more display on tv screen sice put in dvb player/recorder how fix?
Rocket11213
Enthusiast - Level 2
I need help why did call id stop on tv screen . use to work fine . check settings good . so why stop and how fix. thanks
Re: caller id no more display on tv screen sice put in dvb player/recorder how fix?
Shamika_VZ
Contributor - Level 3
Hello,
We can check for you here. I sent you a PM to get started.
Shamika_Vz
Verizon Support
Notice: Content posted by Verizon employees is meant to be informational and does not supersede or change the Verizon Forums User Guidelines or Terms or Service, or your Customer Agreement Terms and Conditions or Plan.
