Customers With Disabilities
  • RESIDENTIAL
  • BUSINESS
    Verizon Business Sites
  • WIRELESS
Zu01
0 Kudos
Actiontec MI424WR Port forward problem.
Hello, my first post and I have a problem. I have has some recent needs to port forward, but I'm having some trouble entering the port forward site at 192.168.1.1. I can get the the login page, but it asks me for a username and password. I've been told these should be admin and password, but that didn't work. Does anyone know how to reset this account or find details on it?
Thank you in advance.
All Star
dslr595148
0 Kudos
Re: Actiontec MI424WR Port forward problem.
#1 Should you be asked for a login, try the following:
admin/password
admin/password1
admin/admin
admin/admin1
Your Verizon Username and Password
Admin/serial number.
By serial number, I do not mean type it words serial number. I mean find and enter in the serial number that is found on the bottom of the router.
#2 If you can't log-in to the router, please post and we will go from there to try to figure out what is going on....
Gold Contributor VII
Smith6612
0 Kudos
[ Edited ]
Verizon gives the ActionTec MI424WR out to FiOS users, so you might have just posted this in the wrong forum or you are in fact using this on DSL. Anyways, if the passwords DSLR above gave didn't work, give the router a factory reset. This will allow you to change the password upon visiting http://192.168.1.1/ once the router reboots.
Remember: YouTube is not a comprehensive benchmark. See the Google Product forums for slowdown issues.
Wireless issues? http://tinyurl.com/mfh3sud
Verizon
  • Services
  • Shop
  • Support
  • Site Feedback
  • Announcements
Shop FiOS
  • FiOS Internet
  • FiOS TV
  • FiOS Digital Voice
  • FiOS Bundles
  • Flex View
Account & Services
Email, News, & TV
  • Check Email
  • TV Listings
