Hi everyone,
I recently have a problem with the ip; it keeps changing to new ip every few days. I understand that IP changes once in a while but not every few days. Anyone knows what's going with this problem? What can I do to stop IP changing?
Any advice pls.
Thank you! K
To better assist you, it would help to know at least:
#1 The brand and model of your modem.
#2 The brand and model of your router.
I am having the same problem, only in my case the IP changes increasingly whenever it rains. In the last two days alone, my IP has changed over fifty times. Considering that this seems to be a weather sesnitive issue, I am assuming the solution will have nothing to do with my router or DSL filters?
@reverends wrote:I am having the same problem, only in my case the IP changes increasingly whenever it rains. In the last two days alone, my IP has changed over fifty times. Considering that this seems to be a weather sesnitive issue, I am assuming the solution will have nothing to do with my router or DSL filters?
These issues are typically outside. You can check inside of your NID and your home for moisture present near the telephone wiring but it will for sure need a tech to come out.
