Need more HELP
minerhump
Chat.. subject slow throughout (DSL), I was going to ask why dsl slow, got this message guess that the answer. Ask question, got this reply.. A verizon service representative will be with you shortly. thank you  12:20:26 Estimated wait time is 36 mins 4 secs. we aplolgize for the delay. Your are 7th in the queue. Guess dsl not to slow compared to this. Not happen. Thanks for listening..
Re: Need more HELP
dslr595148
Community Leader
Community Leader
tep one: Visit http://www.giganews.com/line_info.html and post up the Traceroute the page shows, if you wish. Be aware that your non-bogan public IP Address will show up.  It might shown up as the final hop (bottom-most line of the trace)  might contain a hop with your IP address in it. Either remove that line or show only the first two octets. What I'm looking for is a line that mentions "ERX" in it's name towards the end. If for some reason the trace does not complete (two lines full of Stars), keep the trace route intact.
For example this what I see
    news.giganews.com
    traceroute to 71.242.*.* (71.242.*.*), 30 hops max, 60 byte packets
    1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 13 ms 13 ms 13 ms
    2 ash-bb1-link.telia.net (213.248.70.241) 39 ms 7 ms 7 ms
    3 TenGigE0-2-0-0.GW1.IAD8.ALTER.NET (63.125.125.41) 4 ms 4 ms GigabitEthernet2-0-0.GW8.IAD8.ALTER.NET (63.65.76.189) 4 ms
    4 so-7-1-0-0.PHIL-CORE-RTR1.verizon-gni.net (130.81.20.137) 6 ms 6 ms 6 ms
    5 P3-0-0.PHIL-DSL-RTR11.verizon-gni.net (130.81.13.170) 6 ms 6 ms 6 ms
    6 static-71-242-*-*.phlapa.east.verizon.net (71.242.*.*) 32 ms 32 ms 33 ms
Step two: Can you provide the Transceiver Statistics from your modem?
#3 If you don't know how to get that info:
a) What is the brand and model of your modem?
b) If you have a RJ-45 WAN port router connected to it: What is the brand and model of the RJ-45 WAN port router?
#4 If you have a RJ-45 WAN port router connected to the modem, even if you know how to get the Transceiver Statistics from the modem: What is the brand and model of the RJ-45 WAN port router?
