HOME CONTROL DISTANCE
Khill3
I spent more than I would have if I had known that the motion detection distance is maximum 15 Ft. So if you intend as I did to watch the sidewalk in front of your home and its more than 15 Ft the camera will never pick up the movement so don't buy it it you have not do so yet. It will only disappoint you. But if you want to watch the front door and mount the camera on the front patio it will show you when the UPS delivered a package. Also there is not a sensitivity adjustment on the camera so every time the wind blows the camera will activate and catch the leaves as they blow across yours patio. Anyway just another expensive disappointment.
Re: HOME CONTROL DISTANCE
James741
Do anyone know about the the night vision capability of the cameras?
Lew_D_Vz
Enthusiast - Level 2
There are three (3) cameras available in the Home Monitoring and Control product portfolio.  Of these, the Outdoor Camera is equipped with a built-in infra-red LED, which enhances the captured video in low-light situations.  This camera can be used in both indoor and outdoor applications.
