Is Verizon going to acknowlege the problems with FIOS and Windows Vista
TimSykes
Gold Contributor III
Re: Is Verizon going to acknowlege the problems with FIOS and Windows Vista
Message 21 of 141
(7,246 Views)
@Provider7 wrote:
 Since Vista's arrival they have already had 3 service pack updates which brings me to the next point...
Service pack 3 is out...are your systems updated to this?
Just a FYI for you XP just came out with SP3, Vista is still on SP1, they are beta testing SP2 right now.
Provider7
Silver Contributor III
Message 22 of 141
(7,238 Views)
Tim, your right...My bad.  I just rebuilt 3 systems and noticed the svce pack 3 on Xp...
Thanks Chief...
cjacobs001
Message 23 of 141
(7,236 Views)
I recall something about changing the network from public to private, or vise versa, on the vista machine as fixing this.
cjacobs001
Techman28
Gold Contributor IV
Gold Contributor IV
Message 24 of 141
(7,236 Views)
that is another option to try as well Excellent info cjacobs001 I completely forgot about that
Provider7
Message 25 of 141
(7,229 Views)
That was the first thing I had him try...Post # 2
Techman28
Gold Contributor IV
Gold Contributor IV
Message 26 of 141
(7,218 Views)
yeah well um hmmmm you got a point there I'll remember to read your post as well next time 🙂
fiostvman
Bronze Contributor II
Message 27 of 141
(7,196 Views)
Can someone tell me(step by step) where to find the option under Vista to change from public to private. I tried looking last night and I could not find it.
 The poster provider wrote [b]Try this and tell me if it works...right clicking network icon >Network and Sharing > Customize > click Public > next > close > restart computer [/b]
Somehow, I did not find  the section starting from "Customize"
BTW, another poster on Broadband Reports was having the same exact problems as I have been. He replaced the Actiontech Router with a Dlink Router and BAM!!!!!!!!  His problems were resolved immediately. No more dropping of internet signals.
Message Edited by fiostvman on 02-03-2009 09:34 AM
Provider7
Message 28 of 141
(7,191 Views)
After right clicking on the icon to the lower right select Network and Sharing Center..
 The screen that should come up is the "Network and Sharing Center".  Below the title "Network and Sharing Center" should be your computer name and a icon of your computer  with a line to network and another line that shows a globe and labled internet.
Just below the globe to the right is the word Customize in blue
To the left of Customize should be an icon with the work labled in bold :Network (Private Network)
Select customize...another pop up screen comes up that gives you the option to select public or private.
JoeK
Message 29 of 141
(7,165 Views)
The problem exist on 'Private' and going to Public on a home network is NOT an answer, even if it worked, which it won't.  I am astonished that people are even sugesting this. To the people who are:  How about, while making this recomendation you explain that you will not be able to see other PC's on the home network, share files, use Media extenders, etc.  In short, totaly disabling all the advantages of having a home network.   Quite a solution!  I have a better idea.  How about Verizon fixing it on their end, because that is where the problem resides.  In short it can't be fixed on our home PC's, because the problem is not on our home PC's.
Techman28
Gold Contributor IV
Gold Contributor IV
Message 30 of 141
(7,156 Views)
one user also tried the following but never heard from on that thread again but connection wizard
