Switch Account
Wireless Signal Weak - Tap into Outside Box Coax Cable and Convert to RJ45 Somehow?
Highlighted
Message 1 of 2
(1,256 Views)
Garage PC is too far away from Verizon Wireless Router MI424WR.
The cable from the underground comes in at the garage and is tantalizingly close!
Can a 75 ohm video type splitter be installed at the garage and some sort of converter box be installed at that point to convert the signal and provide a hardwire connection to the network card in the garage PC?
If possible, does Verizon have this converter for a reasonable cost or can you recommend an alternative?
Can an extra STB from Verizon be installed and use the "ETHERNET" RJ45 connector on the rear panel?
1 REPLY 1
Highlighted
Gold Contributor III
Re: Wireless Signal Weak - Tap into Outside Box Coax Cable and Convert to RJ45 Somehow?
Message 2 of 2
(1,244 Views)
The underground cable is fiber.  You can't tap into that.
Yes.  You can tap into the coax coming out of the ONT and use a MOCA bridge to provide an ethernet connection in the garage.
See the following FAQ:
Can I get an ethernet connection in a room with only coax
VZ does not sell MOCA bridges.  See the above FAQ for sources of MOCA bridges.
No.  The RJ45 connection on the STB is not active.
