Get gifts fast with In-Store & Curbside Pickup or same-day delivery.
A Working Fix for 7100 box + TV = Unresponsive remote ...
SOLVED
Highlighted
Copper Contributor
Copper Contributor
Re: A Working Fix for 7100 box + TV = Unresponsive remote ...
Message 11 of 12
(4,375 Views)
I ordered it from them and it worked for me. I have a Panasonic 50" Plasma. The only other thing that worked before was to turn my screen brightness way down. I put the IR sensor end right under the bottom of my TV so that the remote has a direct line of sight to it. This fixed the issue right away.
Highlighted
Copper Contributor
Copper Contributor
Message 12 of 12
(3,774 Views)
I have the same issue with my LCD TV.     The tape solution works great.
I did find that the tape only has to cover the upper left  area where Message text (and the message light) appear.  I wanted to still wanted to see the green "On" light.
