Best FiOS remote code for Samsung LCD TV (model LN46D630)?
FWEhr
Bronze Contributor I
Message 1 of 2
(4,205 Views)
Hello,
Have the Philips Philips RC144**** remote and new Samsung flat screen. So far I am using code 0729 which works fine for Power, Volume, Mute and Source. BUT it does not allow access to TV menus. For example:
  1. Press TV
  2. Press Menu
  3. Get top-level Samsung menu list
  4. Press >  [right arrow]
  5. Get displayed "Not Available."
Yes I am a bit lazy and would rather not cycle through the 20-odd other Samsung codes, and would much appreciate if anyone can tell me:
(a) what other code, if any, allows more of the TV functions to be used via FiOS remote, or
(b) whether this remote (or remote + 7216 STB) simply do not allow such functionality
Thanks!
1 REPLY 1
Blackie50
Re: Best FiOS remote code for Samsung LCD TV (model LN46D630)?
Message 2 of 2
(1,497 Views)
Unfortunately, the FIOS remote is only able to do what you already are able to do.  It will not replace your manufacturer's remote for settings or internal adjustments.  Not designed to do that.
Good luck!
Modal Dialogue Title
