Help with Verizon FIOS Remote Control - text with number keys
msantos1116
Message 1 of 2
(604 Views)
My FIOS remote has number keys that look like they can also be used for text input.  However, I can't seem to figure out how to actually use the number keys for text input.  It would be much easier to use the number keys instead of having to scroll to each individual letter when I am searching for a program or a movie.
Is this function available?
1 REPLY 1
CRobGauth
Re: Help with Verizon FIOS Remote Control - text with number keys
Message 2 of 2
(520 Views)
Not that I have seen.
