I find that pausing for a second brings sound back after resuming play. Also, rewinding and replaying brings sound back in the same segment that just had no sound so it's not an external connection issue but instead something with my in-home equipment.
If I were to guess I'd say the sound drops out when the STB or Multi-Room DVR are being heavily taxed with other tasks and the processor can't keep up.
Is there a solution to this aside from requesting a new DVR Multi box?
08-23-2019 07:59 PM
No, I'm still experiencing the problem. Sound drops out when playing back a recorded show. Hitting pause and then play restores it. Annoying to have to continuously hit pause, play. Any solutions? Verizon Tech please DM me to discuss options.
08-24-2019 04:18 PM
Answering blindly here as I don’t have Vz STB’s (I have TiVO), but I had similar issues and ended up fixing it by changing the signal output from the Tivo to th3 TV from Dolby to PCM. Is there a similar “audio” settings option on the STB? (When I had the Vz STB’s a while back, there was also a hidden menu that could be accessed when the box was powered off to check as well. Maybe one of the other folks who frequently answer here will know where you might find that setting to give it a try.
09-20-2019 07:54 PM
I have the same problem and it does appear to occur only on the media client. Haven't seen an answer on this forum yet so I'll have a chat with Verizon. Will update this group if I get an answer.
09-21-2019 05:38 AM - edited 09-21-2019 05:39 AM
@lasagna wrote:Answering blindly here as I don’t have Vz STB’s (I have TiVO), but I had similar issues and ended up fixing it by changing the signal output from the Tivo to th3 TV from Dolby to PCM. Is there a similar “audio” settings option on the STB? (When I had the Vz STB’s a while back, there was also a hidden menu that could be accessed when the box was powered off to check as well. Maybe one of the other folks who frequently answer here will know where you might find that setting to give it a try.
What you may be referring to is going in the service menu and changing to LPCM. Been documented many times, but again: power off at box, OK 2X , left arrow, user menu, Additional HDMI settings, change audio to LPCM, power.
