Need help recoding programs to my VCR
Highlighted
Nickel Contributor
Nickel Contributor
Re: Need help recoding programs to my VCR
Message 21 of 32
(9,550 Views)
I'm still getting snow when try to tape a program from my  DVR ,if I every thing  all conected the right way will it  play back the snow iI recorded or will it thape the program that I taped
I have 6 plugs altogether 2, red,2,yellow, 2 whitle to I need to use all of them
The 6 plugs did come with my DVR player
Message Edited by KJH278 on 04-26-2009 10:33 PM
Message Edited by KJH278 on 04-26-2009 10:39 PM
Highlighted
Bronze Contributor II
Message 22 of 32
(9,517 Views)
Could you possibly post what brand/make/model of your TV, VCR, and which DVR you have?
Highlighted
Nickel Contributor
Nickel Contributor
Message 23 of 32
(9,496 Views)
TV- Sony
VCR/DVD- Sony  SLV-D300P
DVR- QIP7200
Message Edited by KJH278 on 04-27-2009 03:51 PM
Highlighted
Gold Contributor VII
Message 24 of 32
(9,416 Views)
In response to your question in the duplicate closed post Geek Squad is found at Best Buy stores - they are techs for hire.
Highlighted
Nickel Contributor
Nickel Contributor
Message 25 of 32
(9,408 Views)
1. how much does the  Geek Squard  charge
2. Can they come to my home
Highlighted
Message 26 of 32
(9,391 Views)
{please keep your posts courteous}
Message Edited by KaLin on 05-04-2009 12:03 AM
Highlighted
Gold Contributor IV
Gold Contributor IV
Message 27 of 32
(9,387 Views)
ok guys use this emulator to help walk yourself in hooking up your vcr to record
http://ceaconnectionsguide.com/
Message Edited by Techman28 on 05-01-2009 02:22 PM
Highlighted
Nickel Contributor
Nickel Contributor
Message 28 of 32
(9,352 Views)
I hooked up  it the the  way Keyboards todl me and it did;nt work
Message Edited by KJH278 on 05-01-2009 09:22 PM
Highlighted
Nickel Contributor
Nickel Contributor
Message 29 of 32
(9,321 Views)
How  come  Keyboards set is not working for me
Highlighted
Copper Contributor
Copper Contributor
Message 30 of 32
(9,281 Views)
jumping into this thread to ask a [dumb?] question.   It seems most of these posts refer to recording from a DVR to a vcr (or dvd recorder).  My question is:
Is it not possible to record FROM a hi def set top box (that is NOT a dvr) TO a vcr/dvd recorder/combo ?  And if so... how?   My recorder is a newer model that is upconverting and has a built in tuner.   But I was not able to get it to work no matter what I tried (though frankly, I think I was trying to go from STB through VCR to TV).
Side question, is timed recording possible, or are we back to the 20th century where you need to watch and record at the same time ??
I am so frustrated, that I put my new vcr/dvd combo right back into the box.
