Switch Account
Noisy power supply fan
Nickel Contributor
Nickel Contributor
Message 1 of 2
(2,863 Views)
I have a QIP7216 and the power supply fan gets noisy sometimes. It is definitely not the hard drive because when I pick up the STB and move it around the noise changes.
It’s mildly annoying at this point because I can disconnect the STB from the power, leave it off for a minute or two, plug it back it, and the noise goes away for a while.
Does anyone else have this issue?
1 REPLY 1
Employee Emeritus
Message 2 of 2
(2,737 Views)
Is your DVR well venthilated?  If it is overheating it may be the reaon the fan runs so high.  Are you still having this issue?
Joe D
Verizon Telecom
Fiber Solution Center
Notice: Content posted by Verizon employees is meant to be informational and does not supercede or change the Verizon Forums User Guidelines or Terms or Service, or your Customer Agreement Terms and Conditions or Plan.Follow us on Twitter™!
