Power supply cord issue with Fiois TV One 4100 boxes
NetworkGuy
Message 1 of 7
(865 Views)
 The supplied !2 Volt plug does not fit the 4100 boxes. Installation is impossible HELP!
6 REPLIES 6
Edg1
Re: Power supply cord issue with Fiois TV One 4100 boxes
Message 2 of 7
(857 Views)
The should be a red plug for the server and green for the mini boxes. What exactly doesn't fit? Can you post pictures?
NetworkGuy
Message 3 of 7
(850 Views)
This is the plug that will not fit - iot is in the background pic as connection C.This is the plug that will not fit - iot is in the background pic as connection C.
NetworkGuy
Message 4 of 7
(849 Views)
These boxes just arrived today so may be a new issue with power cord suppliers?
Edg1
Message 5 of 7
(794 Views)
Yes that is the correct power supply. It fits both the 1100 and 4100 media servers. The green ones connect to the mini boxes. If it doesn't fit the connection on the box or the power supply must be damaged. You will have to call Verizon to sent you a new one.
Verizonn8mare
Message 6 of 7
(155 Views)
At least the folks that have power supply issues received a cord.  My unit arrived with no power cord at all.  Disgraceful.
GaryDM
Moderator Moderator
Moderator
Message 7 of 7
(152 Views)
