Switch Account
Premium Channel Order...need help
Highlighted
Message 1 of 2
(986 Views)
I ordered a new premium channel online  and I reset my set top box and the channel still shows as not ordered.  I double checked my confirmation emIl and the link to check the status shows a date a week in the future.  Is this correct and if so is there anyway to get it sooner.  Thank you in advance for any help you can provide.
1 REPLY 1
Highlighted
Re: Premium Channel Order...need help
Message 2 of 2
(917 Views)
Can take up to 24 hours for a channel to become active.
