Prental Control PIN? I need to reset my Parental Controls for my FiOS TV
SOLVED
tawani
Message 1 of 6
(18,799 Views)
How do I reset my Parental Controls for my FiOS TV? Almost all my channels are coming up as "Blocked by Parental Control" and require a PIN to open which I was never given.
I have called technical support but their hours of operation are only from Mon-Fri 8:00am to 6pm. Just exactly the time I am at work and unable to call.
I have tried to "Manage" the Parental Controls online but the thing is not working, keeps giving an error message "We are unable to process your request at this time. We apologize for the inconvenience. Please try again." since yesterday.
Is there anything else I can possibly do?
1 ACCEPTED SOLUTION
Accepted Solutions
prisaz
Platinum Contributor III
Re: Prental Control PIN? I need to reset my Parental Controls for my FiOS TV
Message 2 of 6
(18,719 Views)
FiOS Internet , TV and PhoneChat now with an agentLive chat not available
English and Espanol
1-888-553-1555
24/7
5 REPLIES 5
prisaz
Message 2 of 6
(18,720 Views)
English and Espanol
1-888-553-1555
24/7
Belinda82
Message 3 of 6
(14,885 Views)
I need help no channels are showing
tns2
Message 4 of 6
(14,883 Views)
Initially its 0000.  If it was changed and you don't know its value, it can be reset remotely by VERIZON.  You would have to contact them.
hj1
Message 5 of 6
(6,010 Views)
Channel 502 CBS is locked I need to unlock parental control I never setup a pin now it is asking for a pin?
ornahp
Moderator Moderator
Moderator
Message 6 of 6
(6,006 Views)
Due to the age of this thread, it will be locked in order to keep discussions current. If you have the same or a similar question/issue we invite you to start a new thread on the topic.
