Problem changing channels, using DVR
acct201
Message 1 of 7
(2,127 Views)
I am having major issues with my main Quantum box.  Changing channels can be difficult if not impossible.  The lag time is unbelievablly slow.  Trying to watch shows recorded with the DVR is even worse; very problematic, sometimes impossible to watch anything on the DVR.
I've changed out my batteries on the remote; tried a different remote, and even rebotted all my equipment several times,  To no avail.
Please help, My father who is 80 years old is frustrrated and I may need to switch my service.
Thank you,
6 REPLIES 6
CRobGauth
Re: Problem changing channels, using DVR
Message 2 of 7
(2,078 Views)
What version software do you currently have?
It is under menu-settings-system info.
There are some more recent releases 4.28 that have better response.
BulletRouge
Nickel Contributor
Nickel Contributor
Message 3 of 7
(1,948 Views)
It is what it is. I've had this problem even since I went to quantum when it first came out. Currently already on 4.28 and it is still really really frustrating.
Only solution is to change providers as far as I know...
CRobGauth
Message 4 of 7
(1,946 Views)
Which 4.28?
BulletRouge
Nickel Contributor
Nickel Contributor
Message 5 of 7
(1,944 Views)
middleware: 4.28.1
UI: 4.28.2
Build: 4.28.3
Arris VMW110
Rebooting doesn't help.
Was really looking forward to APR-2.0; sounded like it would resolve the problems, but it is still really really bad...
ryder85
Nickel Contributor
Nickel Contributor
Message 6 of 7
(1,807 Views)
I've had the same problem. Also have a problem with FastForward and Fast Reverse.  I'll FF during a DVR recordeded program and hit "play", but the FF just continues on.  Then I have to hit FR a couple of times to stop and go back and then, hopefully, the Play button will stop it somewhere where I want to be.  Also, the lag time in doing almost anything is ridiculous.  I visited my sister this weekend and she has Cox.  Everything was crisp and immediately responsive. Not a bunch of picture Icons to slow things down and take up otherwise useable space.   The search function also presents full results chronologically and is also informative, not almost useless like now with Verizon.
Ronarino
Message 7 of 7
(1,742 Views)
Same problem here, upgraded 5 new boxes and all are terrible.  I thought it was remote at first, changed batteries, etc.  They started moving to each room and same issue.  I can't even find a way to let Verizon know online, like it's going to matter though.
Modal Dialogue Title
