Problem with Fios Voice Remote Powering Off TV
SOLVED
Highlighted
MVP MVP
MVP
Re: Problem with Fios Voice Remote Powering Off TV
Message 31 of 50
(987 Views)
Please try this too for support and let me know if it helps.
Menu -> Settings -> Audio & Video -> Video Settings -> TV Input Control -> Enable
Thanks
Highlighted
Nickel Contributor
Nickel Contributor
Message 32 of 50
(977 Views)
I did and just answered, but this application never lets you see whether I answer or not, or I should say, THAT I answered.
Here again : I did as suggested. When I turn OFF, the present channel is off, BUT immediately promotions ( still format) come up, like Bad Boys, then many others, one after the other.
Highlighted
MVP MVP
MVP
Message 33 of 50
(970 Views)
Ok, what you are seeing can be gotten rid of by going to menu>settings>system>notifications and then disable promotions and recommendations. I thought the problem we were dealing with here is your TV not turning off. The Fios box itself NEVER completely turns off, there is always a screensaver.
Highlighted
MVP MVP
MVP
Message 34 of 50
(903 Views)
Ok, support wants you to try this, EXACTLY as it's written. They think they may know what's going on:
  • Menu -> Settings -> Audio & Video -> Video Settings -> TV Input Control -> Enable
  • Make sure CEC enabled in Samsung TV
  • Menu -> Settings -> Voice Control -> Fios TV Voice Remote -> Program Fios TV Voice Remote -> Reset Remote setup
  • Menu -> Settings -> Voice Control -> Fios TV Voice Remote -> Program Fios TV Voice Remote -> Auto setup
  • Complete the Power and Volume verification screen steps that follow
  • Now check if Power/Volume is working on this TV
Highlighted
Nickel Contributor
Nickel Contributor
Message 35 of 50
(839 Views)
Tried all of above EXACTLY. A number of times. Does not work .
Highlighted
MVP MVP
MVP
Message 36 of 50
(835 Views)
Ok, Support is looking into a fix. It looks like the APR 6.9 update may have broken the remote codes. Hang in and they'll fix it, hopefully soon.
Highlighted
MVP MVP
MVP
Message 37 of 50
(764 Views)
Please try this and report if it helps:
Another thing we would like the user to try would be to try and pair his working remote from one of his IPCs to this VMS STB where he is currently seeing the issue and see if that works.
Would be best to first invoke reset programming on his working remote, followed by invoking Play/Pause+0 from his remote once in direct vicinity of the VMS to pair.
That would help us rule out if he is seeing a remote issue or a box issue.
Thanks
Highlighted
Nickel Contributor
Nickel Contributor
Message 38 of 50
(643 Views)
Is there any progress re the remote?
Highlighted
MVP MVP
MVP
Message 39 of 50
(639 Views)
Sorry to say I haven't gotten any new ideas for you from support. Did you try posting here:https://www.dslreports.com/forum/vzdirect, and telling them about the issue? that's a direct line to support.
Highlighted
MVP MVP
MVP
Message 40 of 50
(609 Views)
Did you try inputting the exact model of your TV when doing the manual programming, or did you let the box do it automatically?  please try manual programming and input the exact model of tv.
