Problem with Fios Voice Remote Powering Off TV
SOLVED
Highlighted
Nickel Contributor
Nickel Contributor
Re: Problem with Fios Voice Remote Powering Off TV
Message 41 of 50
(802 Views)
I did it automatically, a number of times, and also quite a few times manually and with exact input of Samsung Model number.
Did not work, so that the Remote would do the proper total turn-off of Samsung smart Tv.
Highlighted
Message 42 of 50
(796 Views)
I can't remember but did you try turning off Video input control on the Verizon box?
Highlighted
Nickel Contributor
Nickel Contributor
Message 43 of 50
(774 Views)
NO, did not turn it off. Makes sense that it stay on, or not???
Highlighted
Message 44 of 50
(770 Views)
It is CEC for the Fios box. It basically turns on whatever you have the box going to when you turn the box on. Sometimes it causes a loop where the other device won't turn off, that's why I suggested turning it off.
Highlighted
Nickel Contributor
Nickel Contributor
Message 45 of 50
(674 Views)
I did turn it off. No difference. No total turn off of TV and not even SOURCE works. Have to do BOTH with the Samsung Remote. There's definitely something bad and wrong with Verizon and they do not fix it, ignore all.
Highlighted
Message 46 of 50
(663 Views)
Trust me on this, there are at least 3 groups of people working on this problem. I don't work for Verizon so I dont have a dog in this show. There's a lot going on that has to be done to fix a firmware issue and that's what this is looking like.  I suspect both manufacturers have a problem.
Highlighted
Message 47 of 50
(471 Views)
Is there a resolution yet? It is already June seems like this thread stop 2months ago?
verizon - any solutions yet?
Highlighted
Message 48 of 50
(453 Views)
Just re-submitted it with support. We'll see if they come up with a solution.
Highlighted
Message 49 of 50
(437 Views)
There should be a fix in the next firmware update. Hang on, its being taken care of. Seems to be a problem with mostly Samsung TV firmware not playing nice with Verizon.
Highlighted
Message 50 of 50
(335 Views)
Also a problem with my Panasonic TVs!!  I have 2.  One is worse than another.  The one that is bad is unbearable.  Sometimes, takes more than 20 off presses to turn off TV, while the STB cycles between FIOS "Press any button to watch TV" and TV on.
