QIP 7216 STB Fan Noise
Incaguy
Re: QIP 7216 STB Fan Noise
Message 41 of 48
(5,494 Views)
This worked! Quieted down after 5 minutes. Thank you
moffett528
Message 42 of 48
(4,758 Views)
I had this issue shortly after an uprade a few months back, but it wasn't constant. Then, over the past 7-10 days, it got worse. I turned it on the other night, and the hard drive and all my settings had been blown away... completely erased! They sent me a new, upgraded STB, which arrived in about 24 hours. It'S unfortunate that I lost all of the recordings on the old box, but nothing can be done about that! I still have everything on the external drive, and this STB has way more storage and I believe a quicker/better processor. Still way better than Comcast, in my opinion.
larrycnb
Message 43 of 48
(4,685 Views)
Had my QIP 7216 for over two years.  Last night, I called Verizon for a different issue (internet speed) and was talked into a two-year agreement for the souped-up 50/25 Fios package.  Tech said my internet speeds would increase within a half hour and they did, as promised.  My TV wasn't on at the time but when I turned it on this morning I noticed the loud fan noise started.  I tried turning it off and it still kept going. Googled it and came here.  Nothing is working to stop the fan except pulling the plug.  I can't beleive how loud this thing is for a fan.  Just wanted to post to keep the thread alive and document it for the next person.  Going to call them in the morning.
jonnyhero
Message 44 of 48
(4,548 Views)
The fan was intermittantly noisy for the past few weeks. Today it started running constantly. Tried the LCD setting tweak, but that did not make a difference. Called VZ. Customer service said it is a known issue and they will replace. This will be my 3rd DVR they're replacing. Based solely on this thread, it's been a known issue for 2 years, why aren't you being proactive and replacing all the DVR's with hopefully a different brand?
CRobGauth
Message 45 of 48
(4,534 Views)
They do have a different brand. It is called Quantum.
fxhavko
Message 46 of 48
(4,510 Views)
What worked?  Can't tell what post this reply is referring to.
kuba
Message 47 of 48
(4,277 Views)
well, you can add me to the list of noisy 7216's, just started out of the blue a few days ago.....
dduncan2012
Message 48 of 48
(3,722 Views)
My QIP 7216 DVR also started running (sounds like the fan) all the time. I saw other posts that said changing the LED display on the box could help. I did that and it did help me (for now).  You might try the following:
Using your Remote Control, go to Menu, Settings, System, Set Top box, LED Brightness, and change the setting to Low.
Hope this helps.
