Remote Control - Help with DVR Box
smilepak
Message 1 of 6
(2,525 Views)
As of recent, the remote control provided by Verizon that control the Motorola 7323-P2 DVR box become spotty. I can change channel on the cable box,  but then I press DVR, no response. I know it is not an issue with the box because i can still control it via android app.
I've changed the battery and still no dice.
How do you reprogram the remote for the Motorola whole home DVR box?
5 REPLIES 5
CRobGauth
Re: Remote Control - Help with DVR Box
Message 2 of 6
(2,515 Views)
No need to reprogram. Remote only supports STB. DO you have a 2 button or 4 button model remote?
WHen you hit buttons on the remote, do you see a light flash on the STB?
smilepak
Message 3 of 6
(2,511 Views)
4 buttons remote. I hit STB, light turns red.
I press channel up and down, it works
I press menu, it works
I press DVR...nothing..I press DVR like 10 times, DVR comes up. I scroll over to my show and press OK, it works
Press fast forwad, nothing
Press fast foward, nothing
ANything DVR related, when I press..the STB light doesn't turn on. So any playback button or DVR button, no STB light. ANything else, STB light.
As if it doesn't know what to do with these buttons.
mchapp1
Message 4 of 6
(2,416 Views)
Same problem here, newbox old remote, went to the store to get a new one, no help.
She gave me a photo copied sheet to reprogram for TV.
lacticacidtrip
Silver Contributor III
Message 5 of 6
(2,391 Views)
The remote control is probably dirty inside. I can post directions on how to clean it, but you may just want to order a new 4-device remote for $15 or order a 2-device remote for free.
Find this post helpful, informative or just something you agree with? Click the red ‘thumbs-up’ button.
Did this post solve your problem? Click the green ‘Accept as Solution’ button.
Hellenww
Copper Contributor
Copper Contributor
Message 6 of 6
(2,373 Views)
We had the same issue when we got our new box. I called tech support and they had to try several different things but after about 30min got it working.
