Remote control of audio receiver
susja
Copper Contributor
Copper Contributor
Message 1 of 5
(1,358 Views)
Hello,
I have DVD/CD Receiver XV-DV430.
I've bought Verizon remote control RC144 5302/00B
I can't control my Receiver using remote control. I entered all codes that Verizon FiOS TV Remote Control suggested but still failed.
Could you please help me with the code I should use to control this device?
Here's the list of Codes for Audio Receiver Pioneer suggested by Verizon: ( none of it worked for me )
0041, 0177, 0558, 0657, 1050,
1411, 3607, 3608, 3625, 3644,
3645, 3652, 3654, 3677, 3678,
3679, 3689, 3690, 3722, 3740
Thanks in advance
4 REPLIES 4
starrin
Bronze Contributor II
Re: Remote control of audio receiver
Message 2 of 5
(1,327 Views)
Have you tried the long and tedious procedure in the instructions as to what to do when none of the provided codes worked?  You might find the right one
susja
Copper Contributor
Copper Contributor
Message 3 of 5
(1,300 Views)
I solved my problem by buying Logitech Harmony Remote control
Jtmhladio
Message 4 of 5
(1,201 Views)
I have a harmony remote 670 I have programmed everything but I think my set-top box and TV are not communicating properly I have the new black motorola 72 box has anyone else had this issue? thanks in advance for your help
armond_in_nj
Gold Contributor IV
Gold Contributor IV
Message 5 of 5
(1,184 Views)
@Jtmhladio wrote:
I have a harmony remote 670 I have programmed everything but I think my set-top box and TV are not communicating properly I have the new black Motorola 72 box has anyone else had this issue? Thanks in advance for your help
I am using several Harmony remotes and they all operate the Motorola 7xxx series properly.  Not sure what the issue is at your location.  Note that the Harmony codes are the same regardless of which remote is in use.
