Remote control problem
Remote to the SBT on one set in my house will not change channels when I turn it on. The TV and STB come on and what ever channel the STB is set on comes up. The remote then seems to go dead. It will not change channels on the STB (yes I make sure and hit the STB button). Now, if I hit the DVR button (and this is not a DVR STB), the DVR menu comes up, then I hit the "exit" buttton, the remote seem to function as normal. Any idea what has happened and how to fix it?
Re: Remote control problem
I had a remote problem also, and performed the reset on the remote. This solved the problem. To fully reset the remote, Press and hold the STB key, and while holding it press OK. Then release the keys, and the device keys will blink twice. Then press 9-0-0. The STB key will blink 3 times to indicate success. You may have to re-program you TV, AUX or DVD keys if you have used them.
This process worked for me.
