10-27-2014 07:02 PM
So I've had this Verizon DVR STB for almost 4 years now. And for the past 2 days, the fan started running non-stop at its fastest and loudest rpm and it is running 24x7.
There's nothing blocking the DVR and nothing has changed about it as such.
All of a sudden the fan has kicked into high gear and has been doing that constantly. What is the solution to this? Do I need a replacement STB now?
10-27-2014 09:04 PM
05-25-2015 05:43 PM
My DVR also started running (sounds like the fan) all the time. I saw other posts that said changing the LED display on the box could help. I did that and it did help me (for now). You might try the following:
Using your Remote Control, go to Menu, Settings, System, Set Top box, LED Brightness, and change the setting to Low.
Hope this helps.
05-26-2015 07:58 AM - edited 05-26-2015 07:59 AM
But as others have said, it is only a matter of time before the box fails.
Fan speeds up as temp increases.
Couldn't hurt to make sure all the vents are clear.
