Verizon FIOS TV DVR Issue with Multi Room DVR
bkagan5
Message 1 of 2
(890 Views)
I recently installed Verizon FIOS TV service and I have the multi room DVR option with 2 set top boxes and 2 TVs.
I currently can not record a show on one tv and watch a different live channel on that same TV simaltaneously.  Is there a different dvr package/service available that will allow me to record multiple shows and watch a different live tv channel at the same time on the same TV?  I am only planning to have 2 TVs and 2 set top boxes in my apartment.  Thanks
1 REPLY 1
CRobGauth
Re: Verizon FIOS TV DVR Issue with Multi Room DVR
Message 2 of 2
(815 Views)
What model stb do you have?
If it is VMS, they you are limited to two shows at a time.
if IPC is one with one channel (even if you aren't watching it) then VMS only has 1 tuner left.
you can set IPC to auto disconnect.
or order enhanced service that gives 6 tuners. So can record multiple shows while watching two more.
