quick menu
Volume control of home theater system
Contributor Uni68
Message 1 of 2
(123 Views)
I just upgraded to the new voice activated set top.   When I turn on my tv now it will activate my home theater sound system but I can only control the volume and mute using the TV remote not the Fios remote.  It was completely integrated with the old set top box.  How do I make this work?
1 REPLY 1
Bronze Contributor II Bronze Contributor II
Message 2 of 2
(98 Views)
After you’ve paired your Fios TV Voice Remote to your set top box, HDMI-connected TVs and Audio systems should automatically be detected and be controlled by your Fios TV Voice Remote.
Go to Menu > Settings > Voice control > Fios TV Voice Remote > Program Voice Remote > Automatic Setup
Once the automatic setup completes you’ll see a “Success” message in the top right of the TV screen,
If this does not work for you, please skip to step 2.
Go to Menu > Settings > Voice control > Fios TV Voice Remote > Program Voice Remote > Manual Setup
Select your TV or Receiver Brand and Model and follow the steps,
You will see a “Success” message in the top right of the TV screen when the setup is complete.
My Verizon
  • Add or Change Plan
  • Suspend My Service
  • Apps
Support
Watch Fios
