Volume up no longer works for VZ P265 on Samsung smart tv
SOLVED
Elnino
Message 1 of 5
(8,926 Views)
Remote worked fine for last year. 4 weeks ago the volume up stopped working. Ordered a new remote and still having same issue. All other functions work fine.
1 ACCEPTED SOLUTION
Accepted Solutions
logan8
Bronze Contributor II
Re: Volume up no longer works for VZ P265 on Samsung smart tv
Message 2 of 5
(8,910 Views)
Curious. Are you able to volume up with the Samsung remote or by press the volume button on the TV? If so then we know it is not a TV defect. Here is one thing that you can try: Key Fix If your remote control is programmed for your TV, but the keys do not work correctly, then you can try using the Key Fix feature to fix the buttons. 1. Press and hold the * and OK buttons simultaneously. • The Red LED will blink twice and then stay on. 2. Press and hold the key that does not work correctly. The remote control will try a new code every second. 3. Once the TV responds correctly, release the button. 4. Press OK to save the current settings and finish programming your remote control.
4 REPLIES 4
logan8
Message 2 of 5
(8,911 Views)
Elnino
Message 3 of 5
(8,878 Views)
Your suggestion worked. Thanks.
RD1
Message 4 of 5
(3,679 Views)
This worked for my Element TV, where UP volume button was not working to control TV volume.  Great solution!
LawrenceC
Moderator Moderator
Moderator
Message 5 of 5
(3,675 Views)
