having problen with battery back-up unit beeping and not working properly.need a tech
reen2gold
Message 1 of 4
(1,260 Views)
Battery Back-up Unit Beeping and not working properll. I need a tech out here asap.
Rere Ligon
3 REPLIES 3
armond_in_nj
Gold Contributor IV
Gold Contributor IV
Re: having problen with battery back-up unit beeping and not working properly.need a tech
Message 2 of 4
(1,256 Views)
Rere Ligon
Have you considered typing "battery backup unit" into the "Ask The Community" search box at the top of this (and every) page?  You just may find that your question has been answered over 100 times.
CRobGauth
Message 3 of 4
(1,237 Views)
This is mainly a user supported forum. If you really need a tech, you will need to contact verizon.
My prefered method is via twitter @verizonsupport.
viafax999
Message 4 of 4
(1,145 Views)
Rere Ligon
The batteries are a customer replaceable part .  Verizon will probably offer to send you one at a much inflated price or you could just go and buy one at batteries +, radio shack etc.
Open the ont and pull the battery out and disconnect it.  When the red light goes out reconnect it, that may fix it for some number of months.
