roku box does not connect with my fios wifi
Passat15
Message 1 of 3
(1,592 Views)
2 REPLIES 2
jonjones
Platinum Contributor I
Re: roku box does not connect with my fios wifi
Message 2 of 3
(1,556 Views)
This site can better assist you.
https://support.roku.com/category/115001360548--troubleshooting
select your model and follow the set up procedures.
also make sure your wifi is enabled on your verizon router, and that the SON (self organizing network) is turned off.
clem53
Message 3 of 3
(1,539 Views)
You also need to see what 5ghz channel the router is set to. My Roku stick wont connect to anything in the ch100 and up range. Set the 5ghz channel to fixed , picked a channel in the 80s, connects fine now.
