9 hrs and counting power company fixed the downed line, verizon your up where are you?
Mendes9
Contributor - Level 1
Not very impresses with Verizon repair efficiency, 9 hrs and counting after the power company fixed the pole and still nothing.  Two trucks showed up, left and nothing.  😞
Re: 9 hrs and counting power company fixed the downed line, verizon your up where are you?
kh-gary
Moderator Emeritus
Hi Mendes9,
Your issue has been escalated to a Verizon agent. Please check your Private Messenger inbox for a message from a Verizon support agent. You can find your inbox by clicking on your username at the top right corner of this page and then clicking the envelope icon that appears at the top of the menu. Response times may vary and may be delayed at this time. Please continue to check your Inbox for a reply from a Verizon agent. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
