Damaged Verizon Cabinet
Nicolebearsfast
Enthusiast - Level 1
There is a damaged Verizon Cabinet on Hitchcock Dr Reston, VA 20191 at the intersection of Sunrise Valley Dr. This is an unacceptable safety hazard. Please fix this ASAP. 
Re: Damaged Verizon Cabinet
KH-OrnEsh1
Moderator Emeritus
Hi Nicolebearsfast,
Your issue has been escalated to a Verizon agent. Please check your Private Messenger Inbox for a message from a Verizon Support agent. You can find your Inbox by clicking on your username at the top right corner of this page and then clicking the envelope icon that appears at the top of the menu. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
