Damaged cable
Nicolebearsfast
Nickel Contributor
Nickel Contributor
Damaged cable
Message 1 of 2
(311 Views)
 There is a damaged cable on 13501 Copper Bed Rd Herndon, VA 20171. This is an eyesore and an unacceptable safety hazard. Please fix this ASAP.
1 REPLY 1
LawrenceC
Moderator Moderator
Moderator
Re: Damaged cable
Message 2 of 2
(301 Views)
Hi Nicolebearsfast,
Your issue has been escalated to a Verizon agent. Please check your Private Messenger Inbox for a message from a Verizon Support agent. You can find your Inbox by clicking on your username at the top right corner of this page and then clicking the envelope icon that appears at the top of the menu. Response times may vary and may be delayed at this time. Please continue to check your Inbox for a reply from a Verizon agent. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
Modal Dialogue Title
