Double Play not appearing as $74.99 in cart
jm610
Message 1 of 2
(683 Views)
Hello,
Both the Gigabit triple play and double play are being promoted as $74.99. In the deals section it says, "was $79.99" which is crossed out and has $74.99 in large type. When I add the double play to the cart, it appears as $79.99 which was the original price. The triple play does appear as $74.99 though. Why isn't the double play appearing as $74.99?
I would just get the triple play but since the fees are higher, the double play at $74.99 would be cheaper.
I've attached screenshots of the deals page and the cart for the double play and triple play. Is there some fine print I'm missing?
https://www.verizon.com/home/bundles/fios/
Verizon double play 12.19.17.PNGVerizon double play cart 12.19.17.PNGVerizon triple play 12.19.17.PNGVerizon triple play cart 12.19.17.PNG
Thanks
1 REPLY 1
jonjones
Platinum Contributor II
Re: Double Play not appearing as $74.99 in cart
Message 2 of 2
(655 Views)
It may be a $5 discount when the order is complete.
you could take a screen shot of the Verizon plans ad. On a computer touch “pntscn” which makes a photo copy of your screen.
on an Apple tablet it’s hold the home/start buttons together and it snaps a picture.
on an iPhone X it hold the volume up/power button together and release.
sorry I don’t know how to do it on an android ☃️
