Filing a claim against Verizon for damage on my property power line
mina223
Message 1 of 3
(430 Views)
How do I file a claim to reimburse me for electrical repair work caused by Verizon's fiber installation?  The underground power line to my house was damaged by crew installing fibers for Verizon.  I need to file a claim for reimbursement for expenses paid to the electrician and electrical inspection.  This has been a common problem in my neighborhood.
2 REPLIES 2
CRobGauth
Re: Filing a claim against Verizon for damage on my property power line
Message 2 of 3
(418 Views)
Have you tried calling 1800 Verizon or hitting them up on twitter @verizonsupport?
LawrenceC
Moderator Moderator
Moderator
Message 3 of 3
(407 Views)
Hi mina223,
Your issue has been escalated to a Verizon agent. Please check your Private Message Inbox for a message from Verizon_Support. You can find your Inbox by clicking on your username at the top right corner of this page. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
