Improper FIOS cable installation
SOLVED
DanDynamic
Message 1 of 2
(599 Views)
Had a landscaper do some basic work using an edging tool around mulch bed. Lost FIOS service. It was determined that when the FIOS line was installed it was only buried about 1.25 inches below surface when it is supposed to be at least 3".
Verizon tech that found the issue even stated it was not buried properly.
Several weeks later we get a bill from a third party company called CMR Claims in Oklahoma City OK for $236.57.
Called them and got a very rude "collections agent" who at one point even laughed and said "Verizon does you a favor by burying the line, they don't have to, they could just let the cable lay on the ground"!!
Just pay the bill since you did not call 811 before digging! Since when is a 1.5" edging tool considered digging?
Called Verizon FIOS directly and they said there is nothing they can do since it is billed by a third party.....THEIR selected vendor!!
Did some research and found many complaints against CMR in OK for exactly the same situations. Filed with the BBB and they have several complaints also but yet Verizon continues to use this company and then claims no responsibility for the installation of their own cable.
Time to look at switching to ComCast
1 ACCEPTED SOLUTION
Accepted Solutions
LawrenceC
Moderator Moderator
Moderator
Re: Improper FIOS cable installation
Message 2 of 2
(598 Views)
Hi DanDynamic,
Claims Management Resources (CMR) is a Verizon authorized vendor that provides invoicing services to recover Verizon’s cost to repair damage done to the Company’s facilities. This includes but is not limited to:
• Buried and Aerial lines
• Poles
• Conduit and vehicles
CMR can handle disputes of claims directly, and works with the local field office that performed the repair. If you wish to dispute a CMR claim, you may contact them by phone at 1-800-321-4158 or by email at bswcomplaint@cmrclaims.com.
1 REPLY 1
LawrenceC
Moderator Moderator
Moderator
Message 2 of 2
(599 Views)
Hi DanDynamic,
• Poles
