Customers With Disabilities
quick menu
ONT BATTERY
ps3
ONT BATTERY
Message 1 of 4 (7,384 Views)
oKAY, i AM READY TO GO BACK TO OPTIMUM.. THE ONT IS BEEPING AND BEEPING..CALLED TECH SUPPORT AND ADVISED HAVE HAD FIOS 1 1/2 YEARS THEY SAY I NEED A NEW BATTERY AND TO CALL ANOTHER NUMBER. IF IT HAD BEEN UNDER A YEAR THEY WOULD HAVE REPLACED IT FREE. CALLED THE NEW NUMBER AND THEY WANT $46.00 AND $10.00 TO SHIP THIS TO ME. ARE THEY OUT OF THEIR MINDS? i IMMEDIATELY CALLED EVERYONE I KNOW WHO HAS THE FIOS TO INFORM THEM OF WHAT THEY CAN EXPECT..SERIOUSLY CONSIDERING GO BACK TO WHERE I STARTED WITH OPTIMUM, IN THIS DAY AND AGE WHO CAN AFFORT TO SPEND $56.00 EVERY 1 1/2 YEARS. ALSO AFTER LOOKING ON LINE IT SEEMS THESE BATTERIES SHOULD ONLY COST $20-30.00, SO WE GET RIPPED OFF ANYHOW.
Bronze Contributor II
Re: ONT BATTERY
Message 2 of 4 (7,365 Views)
Hi, you don't have to purchase the battery online. You can go to any store like Radio Shack and purchase one for much cheaper.
~~ "It's not a bug. It's an undocumented feature."
ps3
Re: ONT BATTERY
Message 3 of 4 (7,351 Views)
UNFORTUNATELY I TRIED THAT ALSO, BUT SINCE THIS IS A 12 VOLT THAT DON'T CARRY THEM
THANKS FOR YOUR INPUT I DO APPRECIATE IT
Gold Contributor VI
Re: ONT BATTERY
Message 4 of 4 (7,353 Views)
Where online were you looking? Maybe you could purchase the battery from one of those places.
"All knowledge is worth having."
My Verizon
  • Check Email
  • Add or Change Services
  • Suspend My Service
  • Manage Services
Support
Watch Fios
