Switch Account
Phone suddenly needs area codes in same area code?
Contributor NMCol
Message 1 of 2
(4,257 Views)
Why is this happening and how do i fix it?
1 REPLY 1
Message 2 of 2
(4,241 Views)
#1 As to why, I point to http://en.wikipedia.org/wiki/North_American_Numbering_Plan
Found with a Google search for why are there area codes.
#2 How to fix it, impossible. Not even moving will help, because it most likely will happen again.
