Switch Account
Removal of Sagging and Leaning Pole
Contributor suries
Message 1 of 2
(131 Views)
I would like verizon to remove a sagging and leaning telephone pole in my backyard.  I cannot reach the right deparment.  How do we get them to fix this?
1 REPLY 1
Moderator Moderator
Moderator
Message 2 of 2
(123 Views)
Hi suries,
Your issue has been escalated to a Verizon agent. Please check your Private Message Inbox for a message from Verizon_Support. You can find your Inbox by clicking on your username at the top right corner of this page. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
