Verizon/GTE utility box
Hako
Message 1 of 2
(438 Views)
The box located in front of my property is damaged, has a giant hole in the cover and must be replaced ASAP before someone step in it. I have been covering it for a few days now. I am very concerned about someone getting hurt. Please replace the cover or fill in the box ASAP. Thanks
1 REPLY 1
LawrenceC
Moderator Moderator
Moderator
Re: Verizon/GTE utility box
Message 2 of 2
(410 Views)
Hi Hako,
Your issue has been escalated to a Verizon agent. Please check your Private Messenger Inbox for a message from a Verizon Support agent. You can find your Inbox by clicking on your username at the top right corner of this page and then clicking the envelope icon that appears at the top of the menu. Response times may vary and may be delayed at this time. Please continue to check your Inbox for a reply from a Verizon agent. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
