Switch Account
Vines on cable/internet power lines.
Contributor HappyWife
Message 1 of 2
(248 Views)
I have vines growing across my phone and internet “power” lines and now the weight of it has the bottom two lines touching. the top is electric and isn’t affexted so PECO won’t touch it.  How do I go about getting these removed? Does Verizon handle this?
1 REPLY 1
Platinum Contributor II Platinum Contributor II
Message 2 of 2
(225 Views)
If you can find where the vines attached to the ground, just cut them off. They will die back and fall off.
