Switch Account
WEB SPACE? I'm at 57% and now have problems
Copper Contributor Jim_C
Copper Contributor
Message 1 of 2
(364 Views)
One or more of the images you selected has resulted in an error.
Error: The files you selected would exceed your maximum disk space allotted. Clear up some space in your directory, or select fewer files.
This is what I get when I try to upload pictures to add to my web pages. I deleted some pictures and I still get the error.  According to the site I have only used 57% of my allotted 10mb of space.  What is wrong? Thanks, Jim
1 REPLY 1
Platinum Contributor II Platinum Contributor II
Message 2 of 2
(345 Views)
How large is the picture file you are trying to upload?
"All knowledge is worth having."
