remote control for laptops
SOLVED
kjsargent
Message 1 of 4
(1,094 Views)
I am looking for software to remotely control my familys pcs for when they take their laptops and need assististance. This is not a frequent need but it does happen at least once every couple of months.
Thank you
Ken
1 ACCEPTED SOLUTION
Accepted Solutions
somegirl
Platinum Contributor II Platinum Contributor II
Re: remote control for laptops
Message 2 of 4
(1,092 Views)
I'm not sure if Verizon offers anything like that, but there's a free program called TeamViewer that might suit your needs.
"All knowledge is worth having."
3 REPLIES 3
somegirl
Message 2 of 4
(1,093 Views)
Justin
Message 3 of 4
(1,078 Views)
I am a fan of TeamViewer. There are several options available, including a free option for personal use which is all you should need.
Another option is LogMeIn - https://secure.logmein.com/. Again free for personal use.
And there are others available, although I have never tried any other than Teamviewer and LogMeIn. For simplicity of use, I suggest you look at TeamViewer first.
Justin
FiOS TV, Internet, and phone user
QIP7232, IMG 1.8, Build 02.54
Keller, TX 76248
kjsargent
Message 4 of 4
(1,073 Views)
I installed and tried  TeamViewer on a pair of laptops.  This was exactly what I was looking for.
Thank you all.
Ken
Modal Dialogue Title
